Nissan Pulsar GTI-R
From Wikipedia, the free encyclopedia
Jump to: navigation, search
Nissan Pulsar GTI-R Nissan Pulsar GTI-R (RNN14)
Manufacturer Nissan Motors
Also called Nissan Sunny GTI-R
Production 1990-1994
Assembly Japan
Predecessor None
Successor None
Class Sport Compact
Body style(s) 3-door hatchback
Layout F4
Platform N14
Engine(s) 230 PS (169 kW; 227 hp) 29 kg·m (280 N·m; 210 lb·ft) 2.0L (1998 cc) SR20DET 4 cylinder 16 valve DOHC
Transmission(s) 5-speed manual
Wheelbase 2,430 mm (95.7 in)
Length 3,975 mm (156.5 in)
Width 1,690 mm (66.5 in)
Height 1,410 mm (55.5 in)
Curb weight 1,220 kg (2,690 lb)
The Nissan Pulsar GTI-R (chassis code RNN14 - aka GTiR, i-R and 'R) is a homologated 2 litre turbo-charged AWD vehicle manufactured by Nissan in Japan between 1990 and 1994 in order to enter the WRC under Group A rules. The body is based on the Nissan Pulsar (aka Sunny) N14 3-door hatchback model, but can be distinguished by the large rear wing and bonnet scoop. It has an ATTESA 4WD system (also used on some U12 & U13 Bluebird models), and a unique variant of the SR20DET engine (not used on any other car).
Contents
[hide]
* 1 Models
* 2 WRC History
o 2.1 Group-A 1991 Results
+ 2.1.1 Group-A 1992 Results
+ 2.1.2 Group-N
* 3 Owners Clubs
* 4 References
* 5 External links
[edit] Models
Main versions:
There were 2 versions of the Nissan GTI-R sold to the general public:
GTI-RA: aka RA / Alpha / Road / Luxury = MODEL NUMBER: EBYNRVFN14xxxx
GTI-RB: aka RB / Beta / Rally / Homologation = MODEL NUMBER: EBYNRRFN14xxxx
(The model number is located on the VIN plate on the firewall in the engine bay).
RHD vs LHD models:
* RHD
The right hand drive versions were manufactured in Japan between August 1990 until November 1994. The total number produced during those 4 years was between 13,000 and 15,000. It is unclear how many of them were RA and RB models (see below for differences). The commonly-quoted figure of 5,000 applies to the first year of production (1990–91), in which Nissan had to fulfill under FIA regulations (5000 models total, with 500 of them homologated) in order to enter as a manufacturer in the WRC. They were priced at ¥2,270,000.
* LHD
The left hand drive models (badged as Sunny) had the different chassis number of EGNN14 and were produced until January 1995. No verifiable evidence has been available of the details (numbers/dates/etc) of LHD versions produced, but it is generally accepted that less than 1000 were in total. They were officially sold in , The Netherlands, Iceland, Italy and France (possibly other countries, but details are unconfirmed).
RA models:
About half way through the production (August 1992), Nissan made a range of cosmetic changes to the RA model. Although not advertised as such, they were extensive enough (around 10 items) to be noticeable as a different phase or series and are clearly defined by chassis numbers RNN14-100000 and above.
RB models:
The homologated model was specifically built to be used for motorsport (Group N rallying in particular). They had the luxury trimmings (such as air conditioning and power windows) removed as standard, and the simple interior trim from the base model Pulsar which reduced the curb weight by 30 kg (66 lb) to 1,190 kg (2,624 lb). Some of the luxury items were available as an option. The engine remained the same as the RA model, but there were a few mechanical changes such as a close-ratio gearbox and a front lsd instead of the open diff from the RA model.
Other versions:
* NISMO
There were several RB versions produced with special Nismo plates (total 21, confirmed by NISMO, Japan), which featured many of the Nismo rally options (suspension, LSD differentials, seats, roll cage, foot rests, etc). Some were used by Nissan as promotional cars, but they could be ordered by private buyers as a Nismo "Complete Car" and were priced at ¥3,140,000.
* GROUP A
The Group A Rally Cars were not sold to the general public. They were specifically built and used for the WRC by the now defunct NME (Nissan Motorsports Europe) as their Works cars. After NME was disbanded, the cars were sold to private buyers, predominately in Europe, where some made their way into Rallycross events. Tony Bardy is currently still competing in UK rallies using the "J3" NME car.
* SUNNY
Sunny was the badge used for the European-delivered EGNN14-chassis (both RHD & LHD) models. Their power specifications (220 PS / 162 kW and 267 Nm / 197 lb·ft) were slightly lesser due to different fuel and ignition maps in the ecu to compensate for the lower octane fuel available in those areas. The EGNN14 also had a different rear number plate surround. In 1992 they were priced in the UK at £20,553.
[edit] WRC History
After producing the required 5,000 examples (500 of them being homologation (RB) models), Nissan entered the GTI-R under Group A rules in the FIA WRC as a factory team (Nissan Motorsport Europe - NME) in 1991 & 1992.
NME only competed in selected rallies during both years (ones they thought had the highest potential for good results), but the expected initial success was not forthcoming, and they never won a WRC Group A rally in the GTI-R. Nissan abandoned the campaign in 1992 after only 9 attempts, funding was redirected to Le Mans and the development of the R390, and NME moved to the FWD Sunny GTI in the WRC F2 category (A7 class) where they had better success with Alister McRae winning the 1995 BRC. Much has been written about the reason for the GTI-R's Group-A failure. The most notable being the uncompetitive Dunlop tyres, the inefficiency of the top-mounted intercooler when engine power was increased to Group A standards (especially in hot weather), and the political and cultural issues between Nissan Japan and the newly created NME (Nissan Motorsport Europe).
[edit] Group-A 1991 Results
* Round 4 - 39th Martini Safari Rally Kenya
o Stig Blomqvist - 5th
o Mike Kirkland - 7th
o David Llewellin - DNF (Accident)
* Round 6 - 38th Acropolis Rally
o David Llewellin - 9th
o Stig Blomqvist - DNF (Differential)
* Round 9 - 41st 1000 Lakes Rally
o Stig Blomqvist - 8th
o David Llewellin - 10th
* Round 14 - 47th Lombard RAC Rally
o Stig Blomqvist — DNF (Suspension)
o David Llewellin - DNF (Electrical)
[edit] Group-A 1992 Results
* Round 1 - 60th Rallye Automobile de Monte-Carlo
o François Chatriot - 7th
o Tommi Mäkinen - 9th
* Round 2 - 41st International Swedish Rally
o Stig Blomqvist - 3rd (BEST RESULT)
* Round 3 - 25th Rallye de Portugal
o François Chatriot - 6th
o Tommi Mäkinen - DNF (Accident)
* Round 9 - 42nd 1000 Lakes Rally
o Stig Blomqvist - DNF (Engine)
o Tommi Mäkinen - DNF (Gearbox)
* Round 14 - 48th Lombard RAC Rally
o Tommi Mäkinen - 8th
o Stig Blomqvist - DNF (Accident)
[edit] Group-N
NME did not enter Group N (Production) cars in the WRC, but other factory-backed Nissan teams did between 1991 and 1993. Most notable were the Nissan Belgium Rally Team with lead driver Grégoire De Mévius, and a Japanese entry (team unconfirmed) driven by Hiroshi Nishiyama.
The GTI-R dominated the Group N Championship (FIA Cup for Drivers of Production Cars) in 1992, taking both 1st and 2nd places.
* 1992 Round 3 - 26th Rallye de Portugal
o Grégoire De Mévius - 3rd (13th overall)
* 1992 Round 4 - 40th Martini Safari Rally Kenya
o Hiroshi Nishiyama - 3rd (16th overall)
* 1992 Round 6 - 39th Acropolis Rally
o Grégoire De Mévius - 1st (9th overall)
* 1992 Round 8 - 12th Rally Argentina
o Hiroshi Nishiyama - 2nd (9th overall)
o Grégoire De Mévius - DNF (Late for start)
* 1992 Round 9 - 42nd 1000 Lakes Rally
o Grégoire De Mévius - 3rd (13 overall)
* 1992 Round 12 - 24th Rallye Côte d'Ivoire Bandama
o Hiroshi Nishiyama - 1st (4th overall)
o Grégoire De Mévius - DNF (Engine)
* 1992 Round 14 - 48th Lombard RAC Rally
o Grégoire De Mévius - 2nd (14 overall)
These results clearly show that the GTI-R had the ability to be a successful rally car at Production Class level.
