Yep, torque curve is very diesel like, drops off after 4K rpm, which is its biggest downfall, limiting my peak HP.
Do you suspect this is down to the size of the turbo you're using Dale?
Joe
brilliant stuff. 60ish increase v nice, shud be proud man. Id say th torque drop off is down to th ga cams, made 4 gud low end bt rubbish top end, there quite pointy compared to sr20 cams so to me tht says ga has short duration. When i got mine tested th torque also dropped off like tht. Looks like th cams even restrict a turbo
T25 upgrade and remap, will see you 160 I'd guess?
Joe
