ditto. be good to see you get traction and pull some scorchers down shakeys. i dont know if its been asked recently dale, but have ou ever thought about an aftermarket LSD? i know you can get phantomgrip etc for SR's just wondered if anythin is available GA fit? and if you have plans?
Only just seen this^
Yeah, ive kept this one quiet, but the GA**DE has a Viscous LSD option box available
Its the RS5F31V.
Same box found on the Micra SuperTurbo abd Cherry Turbo AFAIK.
Ive thought about sourcing one, but then the big downside is that they seem no stronger than the stock box.
If they were strong, it would make a nice investment.
Small update for today on current turbo build situation:
Currently have acquired the following parts:
S13 200sx Garrett T25 Turbocharger
Coolant Banjos
Protech Shorty Manifold
JWT S1 Turbo Camshafts
SR20 MAF and Connector plug
91-94 Sentra Fuel Rail
330cc VE Injectors and Connector plugs
I can confirm the sentra 91-94 fuel rail is compatible with our UK GA**DE Inlet manifold, ive test fitted today and also installed the VE injectors into the rail. Also to add to this, the injectors are different in the placement of the fuel inlet mesh, (see shaggys thread on injector upgrades for more info) but they do still fit/work fine.
So were getting close now, only a few bits and peices left to get. Just need to pay for the coilovers, then i can continue buying the remaining parts.
Going to make an attempt of fitting a GTi throttlebody too, wil keep you updated on this.
