the apexi power FC isnt a full stand alone unless you can source the D-jetro unit that can run a map sensor instead of the MAF..
as for all the debate.. standalone or chip its all abit bollocks as for an N/A car all you need is to be able to do the ign and fuel.. the more expencive the more resolution youll get but for 99% of the cars on here a nistune would be fine or even a dastec if your going TB's then a d-jetro or standalone is your only option most of the expencive ecu;s and standalones have features most people on here would never ever use!
Since when does a stand alone system need to get rid of the MAF?
The Apexi Power FC replaces the stock ECU, plugs into the stock harness, uses the stock sensors and allows you change just about any parameter you can think of...
Ignition timing
Fueling
Injector size & latency
Sensor resistance and voltage scale
MAF size (and voltage scale)
Cranking igntion timing
Idle (both base and while under electrical load)
RPM limit
Temperature voltage adjustment
...and a shit load of other stuff that I can't remember off the top of my head.
It would suit 99.9% of applications and since nobody in their right mind is going to run ITB's on a daily driven / weekend track car, without running an enclosed plenum or chamber, then there is no concern in using a MAF.
ITB's open to atmosphere, yes, you will have to use a MAP sensor, but you will also have other concerns, such as idle control and vacuum control.
Bang for buck, so to speak, it is the best system there is!
