since when did a UK spec sunny rev to 7800??!!! those speed figures for a UK gti box seem off cos of the revs involved, speeds probablyb right, not the 7800k revs,
Mine's a UK almera GTi non lsd box with an n15 pulsar 1.8 gti ecu. It had the 112mph limiter on before but if you hit it you were crawling tothe limiter and it killed the power a bit.
I thought Jez had removed the limiter but i can't be sure i'lle-mail him.
iirc, the almera gti box topped 3rd gear out at about 90mph at 6750rpm, and 4th was about 115-120, therefore revving to 8k now 3rd at 8k could be near 112 ish, and 4th at 6600 is as well?
Only thing puttin me off this theory is how severely it cuts the power, but if the limiter momentarily cuts power and i'm accelerating quickly to that limiter, just a momentary cut will feel like a brick wall....
Just seems too odd it cuts in 3rd at 8k, 4th and 6600rpm, and not at all in 1st or 2nd
8k in 3rd won't be 112mph, it'll be around 100mph. Does it do it in 5th? It definately won't be pinking, you need headphones to hear it and if it jumps to it's knock map it's only 2 or 3 degrees less than the normal. That won't cut the engine like this. lol
yeh thats the only thing i wouldn't think 8k would be that high a speed, but i can't see what else it is.
i need to nip on the a1 to try it in 5th so i'm not sure atm.
as for pinking it definitely isn't i agree, although i've heard mine without headphones a few times lol, on the rollers the run where it made 210 but knocked, i heard the knock from the other side of the room with the fans and everything on lol
