just thinking how the guys do it from Aus im sure they do not rebuild the box they just use the standard QG18DE box. im guessing the ratio's are different + the may be slightly stronger.A QG box would last 5mins with a turbo by the sounds of it!
Whats happened bro has your supplier gone dry haha? You just talked sense x
lol Doh!
There is a difference between the QG15 & 18 gearbox. (See my post in the SR20 clutch/flywheel G.B)
anyway a mini clip of my exhaust from inside of the car (not the best will get some more when the gearbox is sorted)
http://smg.photobucket.com/albums/v256/Darren198712/?action=view¤t=DSC00055.flv
well after some research it is pretty pointless doing anything with the QG15DE. the QG18DE gearbox will not fit the QG15DE. this is due to the fact that the input shaft on the QG18DE is slightly bigger then the QG15DE one. the QG15DE shares the same gearbox housing as one of the Micra's im not 100% sure which one but I know it does as I have a micra gearbox ready to go into my car. I can't find a QG15 Gearbox so I had no option.
only real options out there is get a QG18DE or a SR20. so QG15DE turbo is out of the window due to the fact that the gearbox will just say no if I do so.
Darren
Darren
Ok so just to clear things up, you were going to do an SR20 swap then you said a week ago that it won't be possible so you're going to turbo the QG15, now you say that's not possible and you'll be doing an SR20 swap again, but even then you're not sure :lol:. Wow your mind must be a right mess of confusion dude!
What's wrong with changing the flywheel and clutch then so you can use the 1.8 box? Also won't the header for a GA fit a QG? Have you been on QG18DE.net and read through all the things they have done?
:wall:
