Darren198712
Just chillin'
well I made a little vid
The first wire I connect is the power wire which will go towards a switch
the 2nd wire is the monitor led wire (Backlight). I will hook it up to a relay so when ignition is on the display will light up otherwise its blank (no back light)
the computer is not the quickest so I had to modify the monitor led wire to the ignition. because I don't want the screen on when the car is locked and alarm is armed. I also downloaded F.lux. F.lux is a program that adjusts the screen brightness (or color) so when its day time its bright and when the time changes (it adjusts the color so the screen is not that bright)
anyway I don't think I am going to be able to fit it till after JAE unless the screen turns up Thursday at latest.
