delete
as wezz says, why not go to dastek ???, they have done his old car so they kinda should know what they are doing with it, plus its just down the road from you. and they got good results.
i am planning to use the dastek again on mine, just havent decided if i will go back down to fife or wallace performance in aberdeen.
yeah had my Prim mapped by him as well...
my view on things...
Jez is a top tuner, for turbos, no doubt about it, for us NA peeps he is not bad, but has a lot of improvement to be done, as my two mapping sessions show below...
went to him first with the following spec..
SR20VE with DE ECU
standard cams 20ve cams
Fuji Header
CAI
cam switching - Int - 4700, Exh - 4900
still had the DE catback on there though...2.25" down to 2"
figure below is at the fly, WHP was 156.
for the above session I just went to him with basic knowledge about the VE, comp ratios etc, and let him work it out as best he could...
I then posted up the graph above on Sr20forums for comments advice etc, and went back to Jez, armed with the info advice given by people on there and got the following..
spent a couple of hours on it, trying various cam switch points, and in the end settled for both coming on at 4600, apart from that the spec was the same as previous mapping...
and gotta say after that mapping session the car was awesome and when the cams kicked in you noticed the difference..should ask shaun about it, the surprise it gave him...
just shows, with Jez when doing NA, you have to push him a bit with more info, as he hasn't done many of them, and is still learning, the more info you can give him when tuning, the better chance you have of getting a better result..
I know it shouldn't be the case, but when ya have a limited choice of tuners for us SR20 peeps, ya gotta start somewhere...
re Steve at FC tuning, we will soon know how he is with VE tuninig as one of the Dutch guys on NPOC is coming over to the UK, to get mapped by him, so will be eagerly awaiting his results...
