the gain from the mapping was a good positive, hp will see what it says after a run at SRR where it was last run for a proper comparison. but as you said the gain from where we started to where we ended up with was very positive and shows hopefully with the cam switch point info found, should be able to improve further. there was a noticeable difference in the drive after as well, so all in all can't complain
didn't get a print out for the torque, but you can work it out looking at the graph, think it peaked around 113-114 lb-ft
