What's the deal with this intake then - what makes it better than the UKDM intake Ross ?
LOW down torques i believe![]()
cruise control, i believe it was on the sentras, the single is for your throttle cable the one which does both is for cruise control
The AAC..
..or idle control valve as its known can be removed..
We have fitted an SR20 Throttle body to a Micra CG13 inlet manifold for a turbo application. and deleted the factory AACV.. / Idle control valve
WHAT management are you using for this boost?.. that is the key..
Good luck with the project.!
You would be surprised how many Seized idle control valves are on the cars in this club, but they still idle fine lol..
Im not as familier about Dastek as I am about other managments so im not sure. I know with our stuff we can, and do.
It can trouble the cold start and enrichment.
Idealy it would be best to leave it. .. but it CAN be removed..
