shaggy_master
brapp brapp!
WEDNESDAY
I didn't have time to update this yesterday as I only did half a day, then I went to run some errands in the afternoon and pop to the motor factors also.
Firstly I connected the clutch cable to check everything was ok.. which it was. until I started the car again. There's a creaking coming from the clutch thrust bearing when the clutch is not pressed.. so the gearbox will have to be whipped off next week and that issue rectified. That is minor though.
Started tidying the engine bay up.. first up was the nuisance / Carbon canister lol. Removed from the car completely:
Where it was connected to:
And Blocked off yo! :
Sorted out the other breather that comes off the rocker cover with genuine nissan hosing:
And blocked off the now unused inlet breather:
Next I had to re-route the Throttle cable properley as its a bit too long (I'll get a GTi one asap)
Also got the car up to temperature properley and fast idled it for a while to see if I could get the fans to function.. and they did Thankfully.. so thats another problem off my mind.
Another thing I'm glad I did was to replace the Battery tray bolts with fresh brand new ones, as the old ones had seen better days.
I also replaced the Gearbox mount plate bolts that go into the chassis leg for all brand new ones.
Joe
Joe
