Fuji gained 6 bhp over ebay header in a recent dyno.
So we all agree that a remap session,will see good gains and improved drivabilty of the car,considering its running on the worse fueling ever at the moment.
Fitting an AFPR would see benefits then.
Also an apexi SAFC setup will help dramatically it has done wonder on my car
Sent from my GT-I9300 using Tapatalk 4 Beta
I wouldnt just fit an AFPR without an AFR gauge fitted. Even with a a 4-1 manifold and big catcams i was only running standard fuel pressure as any higher and it ran super rich. Dont forget if you up the pressure to add fuel between 3 &4.5k you're adding at 1.5-3 and above 5k where its not needed. Its n equal adjustment across the whole board and not an effective means of tuning.
Different dyno, different day. So no real comparison.untill you look again @ chucky afr - arguably weaker mods with more powerz
