Ve would be an expensive option though. Id have to pull the engine out and pull a freshly rebuilt bottom end apart. The ecu I have won't control the vvl so i either need to upgrade it or get window switches. I also think with a vvl head id struggle on some of the tighter hills to keep it on the 'high cam', this is an issue that the honda lads have. There is also no off the shelf manifold to bolt the itbs to a ve head so a custom one would be required which again isn't cheap.
The thing steering me from a ve really is that to do it properly I'd really need to build a new engine from scratch and I cant warret doing that having just built the current one.
The long term goal for this car is to move to C0 class and build a 2.2-2.4 engine. When I start that I will definately be looking at ve from the get go.
What I'm really swaying between for this engine is a high spec highport head or converting it to a 54c head. Will cost the same to get them to the same spec and there will likely be more to gain from a 54c but I'd have to risk fucking up a brand new block by drilling and tapping the bolt holes. Also means the block is pretty much useless for anything else in the future. Which is why I'm back considering a solid lifter converted highport, but then I'm using the most restrictive head!
Can't bloody win...
Can't bloody win...
