N16 SR16VE
Cheers mate, yeah thats no biggy! Thanks for measuring them for me :)
Oh yeah sorry, I forgot to reply to that last nite!
well I guess I've found out why this lambda died at crail
looks like all those hard 4-5k launches had been battering the lambda against the engine bay subframe lol
how the hell did that happen? You got a Toyo sports mani? The only thing it can hit is the rad?
yeah a toyo manifold but its a ve not a de bud, the lambda goes just before the cat not in the primary of no4, and because of that it was hitting off the subframe. thankfully I'll be changing manifold eventually so it wont be a problem for too much longer lol
QG pump will not work mate but the pipes will u jsut have to block off what i think is a couple of return or vac pipes that are on the pwr steering pump side of the pipe
  • Like
Reactions: IT
The 2 little fuckers that are a pain to get to? ha! I had to disconnect them when I put the QG18 in as I couldnt get pipe off the rack itself!
yeah that will be them we have a pipe going back on itself joining those two pipes so its up to u block them or stick a pipe on them but other than that the n16 pipe will fit the sr pump :)
yeah those two lol, they hook up to the inlet Mani and the evap cannister so I think they may be some kind of pressure release if the pressure gets too high, but like Willie said I just looped them together with a 4" piece of the hose, also the main powersteering hose goes onto the SR pump ok, it just sits at a different angle and as such makes it a little tight, so you can either cut off the locator pin or just bend the metal pipe where it connects to the rack a little to give some slack, I opted for the latter :)
  • Like
Reactions: IT
