N16 SR20DE
Looking good bro so need new bushes fitted on mine so much easier when the beam is off the car.
Sent from my iPhone® using Tapatalk
nice one Liam, but I can't help but worry about painting the discs, I know others on here have done it but when the packing grease on discs can fook up pads then the mind boggles on what paint will do, and even worse paint with waxoil through it :/
-- sent from the dark side of uranus, using my magic stick --
Good work Liam except the discs - they're not supposed to have anything sprayed or painted on them (the disc to pad surface area). The hubs & carriers are fine . . . . . :)
Surely the paint burns/wears away after a short time though.
-mobile phone post-
maybe the person he mows down and parylises/maims cause he couldnt stop in time?
its not the discs it fooks, it's the pads, and like I said before if the packing grease that comes on the discs can knacker the pads friction material...
Yeah I know were talking about the pads. But the material in pads is a damn sight tougher than dried paint, and that's a point in fact, dried paint will not be absorbed by the pad like grease would.
-mobile phone post-
would it not just flake off in time?
why is there always so much negativity all the time on thIS forum by certain peeps, its really starting to pee me off :(
have you ever seen dried pain heated up ed? like with a heat gun, turns to gum, though vht may be a little more resistant to that? but still painting disks is a bad idea full stop, if you really want the non used parts painted then mask the important areas before painting ;)
Preaching to the converted mate as I did exactly that in my how to :).
But I don't believe its as bigger problem as its made out to be. Can't see the pad even absorbing gum'd paint. The pad isn't that permiable.
-mobile phone post-
Whats the fucking problem? They're MY discs on MY car and I have painted them. I have NEVER had a problem, NEVER ran anyone over and NEVER failed to stop because of it.
your not doing things the correct and normal boring aoc negative bunch crowd's way, its being different which leem you are different :lol: :thumb:
