Been out again today and most things went to plan, reconnected the handbrake cables, remove all the front hubs/brakes/wishbones, poly'd the wishbones (took a while to get the old bushes out, lots of heat required!), removed the struts, undersealed in the arches (found quite a bit of rust in the top of the passo one :S wire brushed it all down and kurusted it first), then tried to put the front lowering springs on, tried being the key word :lol:, couldnt get the top mount nut off, its a 17mm nut with the centre having an 8mm bar to hold, the nut was tight all the way and once id ran out of 8mm bar to hold with the spanner i could go no further! So still standard susp up front now.
Was now time to reassemble, wishbones on, struts on, hubs on, new TRE on, brake brackets, disc and calipers on, new pads fitted (R34 GTT pads fit perfectly, no overhang YAY!), driver side brake line on, got to the passenger side and I couldnt get the fucker undone, ended up rounding it. So I now need a new brake pipe from MC to the front passo. Started making it, fucked up 3 flares in a row so gave up.
Didnt get home til 6ish, which meant I missed my poker tournament which started at 5
. Balls.
So far its taken me 14hours, ill have to go back out tomorrow morning to attempt the brake pipe again and then hopefully get it finished.
