Sound job man, i did have all the lines off for a week when i was undersealing, thats why i was bleeding it at the abs pump. It did make a slight difference but barely. I'll try bleeding it again tonight and see.
There is no other mention of a separate bleeding sequence for ABS models. Looks like you need to check the system over, check the master cylinder if you had that removed too, make sure it all went back together as it should and there isn't a leak
Sent from my SM-G900F using Tapatalk
