I cant get any of this to check out. What numbers and calculator are you using Ross?
I use this one
http://www.csgnetwork.com/compcalc.html
If i plug the numbers of a 1mm piston to deck clearance into 10:1 DE specs, i get this:
Bore: 86mm
Stroke: 86mm
HG Bore: 87mm
HG thickness: 1.2mm
Combustion chamber CC: 46.5cc
Piston Volume: 0
Piston to Deck Clearance: 1mm
= 9.4:1CR
If i plug the numbers of a flush deck, which is Ross' Autech theory im getting:.
Bore: 86mm
Stroke: 86mm
HG Bore: 87mm
HG thickness: 1.2mm
Piston Volume: -0.5cc (accounting for valve reliefs)
Piston to Deck Clearance: 0mm
=10.23:1CR
Neither of these are even close?
The thing that bugs me is that i cant get this bang on 100% with my own theories.
Here's what i mean, its much closer, but still not perfect:
These are my 10:1 DE stats
Bore: 86mm
Stroke: 86mm
HG Bore: 87mm
HG thickness: 1.2mm
Piston Volume: 0
Piston to Deck Clearance: 0.05mm
=10.26:1CR
My Autech headskim Theory
Bore: 86mm
Stroke: 86mm
HG Bore: 87mm
HG thickness: 1.2mm
Combustion chamber CC: 40cc
11.42:1CR
