Sams VZ-R N1
Just pulled it all out as I was staring at the car wondering what to do..
Ive worked out I can use the old braided lines I have to link the M/C to the rear 2 hoses, though Im not set on keeping them there yet.
Should have some copper lines bent up soon, I have all the materials to do it, just not the inclination or the means yet.
unbelieveable, i spent the day getting fucked off as i have to replace the front to back lines, looks like your binning some perfectly good ones! i was worried about having to bend new copper ones into shape as its alot more maliable than the steel, but it wasnt too hard to do an alright looking job
Yeah after a lot of pondering I managed to remove them all without even bending them :) hell of a faff as the hydraulic clutch hard pipe pinned them all against the bulkhead
Yeah I really Liked it on the Autech, should be good with the Wilwoods, just wish I could find a Non ABS 17/16 Master Cylinder somewhere :(
If you do, let me know. The SRi one is probably up to the same job as a GTi but i too would like something a bit beefier for the Wilwoods. Are yours the smaller size ones for the GTIR?
Ive spoke to probably 30 people looking for one but turned up nothing yet as they were only on cars for about 2 years.
SRi MC is exactly the same size as the GTi one 15/16"
Il measure the Pistons on the Wilwoods but yeah they are for a GTiR.
I want to get rid of the longer pedal travel I know I will have.
Can't speak for non abs but with it, the pedal was a little bit too spongy.
I wonder if getting a different servo might help? Modernish cars nearly send me through the windscreen at work as i stomp on them like i do the gti.
Not doubting they work, but even the FTO brakes lengthened the travel of the pedal, but they still worked great.
The GTi brakes on the Micra are the perfect example really long pedal travel, swapped to smaller SRi brakes and they are pretty perfect now, nice hard pedal right away.
-Phone-
Altima is 15/16"
Almera is 7/8" iirc. (can confirm on Nissan 4 u)
3 bolt mount waiting for a poly.
