Sam, you do know the 300zx master cylinder is 15/16" too? So I can't see the pedal travel being any worse between using 4pots on that and using them on an Almera.
these are the MC's i've found and considered using but i need ot find out how long they are so they dont foul on the back of the engine. all of these MC's will fit a 300zx and if that one fits an n15 then here we have a list to work form
46010-30P01 Manufacture date 2/89 – 7/90 (17/16″ NA Tokico)
46010-30P02Manufacture date 7/89 – 7/90 (17/16″ TT Tokico)
46010-30P02Manufacture date 7/90 – 2/91 (17/16″ NA & TT Tokico)
46010-30P10Manufacture date 2/89 – 7/90 (15/16″ NA Nabco non-ABS)
46010-30P21Manufacture date 2/89 – 7/90 (17/16″ NA Nabco)
46010-30P22Manufacture date 7/89 – 7/90 (17/16″ TT Nabco)
46010-30P22Manufacture date 7/90 – 2/91 (17/16″ NA & TT Nabco)
46010-45P00Manufacture date 9/91 – 9/93 (1″ NA TT Tokico)
46010-45P00 Manufacture date 2/91 – 9/91 (1″ NA & TT Tokico)
46010-45P20 Manufacture date 9/91 – 9/93 (1″ NA & TT Nabco)
46010-45P20 Manufacture date 9/93 – Up (1″ NA & TT Nabco)
I've had both (still have my broken cusco one...), and the Whiteline one has LOTS more ground clearance, sits up real close to the crossmember (my cusco was 2 fingers off the crossmember) and the rearward mounting of the whiteline brace is also a lot better and lower profile than the Cusco brace giving more 'departure' ground clearance when going over a speed bump.
After an incident resulting in the previous shifter getting lost somewhere I purchased another and have had it all modified again, collected it yesterday with a new PTFE bush in the bottom mimicking the offset that the standard shifter has.
The modifications that have been done on it are;
Pivot ball machined down and shaped to match the stock shape/size allowing me to keep the plastic cup bit, a bend put in to mirror the stock shifter then the bush at the bottom that is allowing me to keep the stock shoulder bolt.
Not far off getting the car back down on its wheels now after far too long sat on stands
Proper fucking snug, had to use the nuts to pull it up onto the car, the collars have moved it forward a considerable amount, looking at the marks from where it was before
Couldnt get all the collars in though only the top ones, the holes on the subframe itself are not perfectly in line with each other.
