Very clean. on closer inspection the rust on mine is quite minimal. Yours look in great condition
I like like to check the dampers recoil while they're all apart too.
I noticed the KOYO? bearings in the front top mounts on mine are starting to feel a bit rough and gritty too. Got the bearing number ready for ordering when they get bad lol
this is a different set, the bearings on the top of these are showing a bit of surface rust but Im going to clean them up and put on some sealant to protect them.
a full set will consist of the ones I have managed to fit, every subframe will be slightly different I imagine, should have something soon enough though.
Engine
JWT 9lb Flywheel
GSpec Stage 3 Clutch
New OEM Thermostat
New OEM Rotor Arm/Distributor Cap
OEM N1 Chain Tensioner
2 Piece Engine Mounted Drive Shaft
Custom 4-1 Manifold
Custom Solid Fabrications 2.5" Catback
Aluminium 3" Core Radiator
Catch Can Breather Setup
DaleSpec 3.5" Intake Pipe
Blitz Sonic Power Filter
Hot Wire HT Leads
A/C Removed
Odessey Battery Wing Mounted
Fuseboxes Relocated
Chassis
FRP Bonnet
Custom Subframe Locating Collars
OEM Track Rod Ends
Steering Rack (Poly Bushed)
OEM Drop Links (Poly Bushed)
Powder Coated Front ARB (Poly Bushed)
OEM Wishbones (Poly Bushed)
4x Poly Engine Mounts
Meister-R Zeta Coilovers 7/5
Powder Coated Cusco Top Strut Brace
Custom Rear Strut Top Brace
Custom Lower 2 Point Subframe Brace
Rear Trailing Arm (Poly Bushed)
Powder Coated Whiteline Rear Anti Roll Bar with Custom End Links
Rear Dog Bone Beam Mount Thing
H&R 15mm Spacers and Extended Studs
Interior
Personal Neo Grinta 330mm Wheel
HKB Boss Kit
NRG Rev.3 Snap Off Boss Kit
Flocked Dash
Custom Extended Gear Shifter
Recaro Seats on Custom Rails
Omori Gauges
Sound Deadening Removed
Apexi RSM Black
Broadway 280mm Rear View Mirror
Wheels/Brakes
Wilwood Midilite Front Callipers
Ferodo DS2500 Pads
Yellowstuff Rear Pads
Custom HEL Braided Lines
Non ABS Converted
15x7" Team Dynamics Pro Race 1.2 & Federal RSR
16x7" Modex KS-05R & Yokohama Parada Spec 2's
15x6.5" Enkei Tarmac ES & Hankook RS2's
