sri_alan said:
if you cut the shaft, your hand moves less but at a lower height, and requires more force
move the pivot down closer to the linkage pivot, your hand moves less but remains at the same height requiring less force
Dale is right aswell, id trust someone carrying out a turbo conversion and who does all the work by themself
Syms, just because 3 or 4 people on aoc say its wrong doesnt mean it is
i actually thought this was gonna go on the correct terms at first, then
got a bit dissapointed by the end. sorry to say
- not saying he isnt capable of it - but why would u trust someone - just because they do their own work - (even coming from someone that does my own aswell)
ive seen plenty of cars come in my garage from come and have a go heroes trying to fix/modify/upgrade things, from bodywork to engine, and ended up coming to me to sort.
People having a go them selves at soem stuff is the reasons why ironing boards are still in fasion on rears of corsa's
right DALE - i take it thats ur name. lol
you are correct- to some sense. as you are moving your hand's throw distance less- but this is your hands throw, not the gearlinkage throw.
although u talked of angular and linear etc. its not that, that comes into play.
yes - hand throw is reduced by cutting the shaft
but - and the reason for having a short shift - is that when the lower section "below the pivot point" is extended - this causes the GEAR linkage throw to be reduced.
doing both will reduce the time taken to change gear, but the amount u are able to actually chop the stick down by, i guarentee u will not even realise the time difference because it will be milliseconds, and u wont be able to clutch/shift quick enough to make a difference
shortER shaft = less hand movement
short shiftER = less linkage movement
On another note i can actually believe i went out to strip a car this morning - came in this afternoon for lunch and checked the site - only to come back tonight and the thread has added 3-4 pages to it :O
lol
interesting battles. possibly taken a bit tooo serious though
i think you should each picka lady of your choice and let them mud fight to see who ends up dirt champion!
QD
