I thought the car has a FPR as standard which is controlled by the ECU?
The ecu should adjust it's self to the new cams by adjusting the fuel / air mixture going by all it's intake/exhaust sensors etc. I'd hope it can adjust enough without needing extra help from a manually adjustable FPR. Last thing I wanna do is be dumping in fuel that's going to waste and meaning pish economy.
Interesting to note that it was only after an ECU re-set that Dave really noticed the difference with the cams...
it's got an fpr yeh, but not adjustable - and i don't think it's controlled by the ecu
i just wouldn't want to run lean at high rpm, be good to see as afr reading before running it for very long without adjusting it - just to be safe.
if you think about it - that standard fpr was set-up with the stock breathing mods too - but with a decent filter and exhaust it's breathing much better with same fuel goin in - which to me says lean - then add cams into the equation...
might be talkin crap though! ....
