Im just glad it gained power with the intake, would be pretty embarrasing if it didn't.
Just needs an adjustable FPR for a bit more juice really. The fuelling is okay, but between 4000-5000rpm its needs more fuel, as thats causing the dip in power. A few more psi should see 13's between 4-5k, and 12's across the rest of the range.
I suspect that this is just a slightly tired engine, its making stock power at over 7500rpm, which is above the stock limiter.
The numbers arent too bad though, ive seem similar numbers from RR DE's with the same mods.
