NaylorGTS
AOC Moderator
Have found some minor annoyances, like the brake clips sometimes touches the brake disc giving a squealing sound - not much I can do about it. The air ventilation dial that elects direction from face to windscreen seems disconnected. Still can't figure out why the fogs don't work - all Relays seems to be there?
The air direction, remove the radio, look down, you can see a black cable(like one a push bike brake cable) connected to the back of the direction knob, see if its caught or not in a clip, but moer than likely it'll be stretched, if you pull on it slightly and adjst the knob you should then start getting air out the windscreen vents, just use a tie wrap round some of the metal framework and round ther cable to give it a bit pull then it'll work all the time.
