Are the GTiR seats a straight swap?
Joe x
OoOoh a kiss, i must be doin summat right lol there a 'nearly' straight swap. i found that the bolt holes all line up, but on the driver seat, the rear mount nearest the tunnel sits too high, so the rear mount nearest the door needs washers or a spacer under it, and on the passenger seat, the mount nearest the tunnel needs washers or a spacer under it, as the mount nearest the passenger door is the same height as an N15 seat..
i should imagine it would be possible to drill out the studs that holds the 2 fore-mentioned mounts, do the same on an N15 seat and bolt or spot weld the N15 mounts to the gtir seat rail, in the same place as the original mount. this should give the correct height of the seat on all the mounts then.
if you could follow my idea then fair play, as i nearly lost myself.
thanks for all the comments to, i know its only a 1.4, i never make it out to be something its not, its good for what it is, but im mega proud of how she has turned out. corbs wants to GA16 it later this year, we'll see
next up is to sort out the weepy sump and she should be good for a few months then. until i spy another possible tommo bodge mod
:thumbs: tom.
