Cheers Dave,
Im baffled at the minute...the car is bizzarely acting fine.
I drove it all the way back from Surrey last night (130mile) and it didnt overheat at all, i drove it to work this morning, fine.
I must admit there was a very small leak (the odd drip) from one of bolts on the water pump housing, which i fixed at work today. (surely this couldnt have been the cause?)
Just modified and swapped the actuator for my old one from the old setup which is a 7psi spring and been out for a test drive to try and get it to overheat.
Keeping an eye on the AFR's, i gave it some welly at 7psi and its fuelling slightly better now- 12.5:1 right past 6.5k (still not quite rich enough for my liking).
In any case, 30minutes of hard abuse and the temp gauge hasnt budged.
Anyone got any thoughts???
Ed@fusion did a block test and the blue fluid only changed colour very slightly to dark bluey green (definately more blue than green).
Although I think yellow is the colour to indicate combustion gases in the cooling system?
I dont wanna tear the motor down or pull it out, with being 100% that a problem exists. I will do a compression test shortly to see if that shows anything up.
On a side note to cheer me up a bit - it fucking flies, even at 7psi.
