rhyd4 said:looking good, have you got any parts for the sr20 like header, cams, flywheel clutch etc? be worth doing bits before it goes back in.
clutch and flywheel have been ordered
sri_alanHey Andrew, what was the problem with the driveshafts? was it the supporting bearing? Im doing my flywheel at the moment and was a bit thrown by the driveshafts, leaving it till tomorrow. What colour are the 2.0 driveshafts? Mine are bright green?!
Project is looking good though, it'll be a nice way to finish off your car!.
the drivers side one is easily removed, its just bolted on to the block so remove the bolts and lever it out, there's also a ring piece which is bolted to the block what the shaft goes thro remove this to
the passengers was the cunt, tricky getting in about to lever it free, this has a green end on it
the
