Andrew's new piccies
what you doing with the brakes mate?? I'm currently doing a conversion as well with a primera sr20de motor. I've got some gti calipers and just mintex pads and disks for now, hopefully with a gti axle on the back. Keep us posted with how yours is going and good luck. If I get any little niggles i'll let you know too!
am not giving much away with the brakes but rowdy-gti knows what it is
they are possibly the first to be fitted to a almera to :D
here's the calipers, 2 pots, and the arent from a nissan ;)
these will be mated up with 280mm disks , goodridge stainless brake hoses and EBC Red stuff pads
Hmm... not from a Nissan... Is it **Decided to remove my guess incase I was spoiling the suprise. PM'd Andy instead** ? I'm sure I read about that somewhere...
better piccies with coilovers
got some better piccies with the coilovers today, unfortunately the sun wasent oot
lowered the front a bit another 25mm
it could maybee go down a bit more but id struggle to get into ma garage
Hmmm...yea i can see what your talking about now with that gap on the side skirts by the rear door. That's just nit picking though...
Looking sexy as ever as usual!!
that will be removed yet once it goes into the bodyshop next year ;)
new brakes
after some advice from Rowdy-gti on a brake set up for the car once the gti engine is in place iv went for the suggestion
as far as we are aware this is a first for a almera :D
here goes
calipers- Mitsuibushi FTO GPX twin pot's
Disks- Renault Clio sport 280mm disks
this will be paired up with Almera gti Stainless steel hoses and EBC Red stuff pads
how much roughly for the set up and would these offer greater stopping power than standard gti brakes? fairly easy swap?
the calipers were £100 for the pair, Disks £50 so cheaper than buying new gti calipers and disks
they are bound to be better than the gti's they have twin pots over one and the fto gpx is a 2.0 V6 that weighs a tonne so they will easily stop the mera
Looking good Andy.......the bigger discs also act as a larger lever in the stopping the car and shed heat faster.
cheers ian, going to do a trial fit tomorrow so fingers crossed
do you need any other mods to fit the brakes or will the caliper holes match the gti. also i assume that these calipers cover a 2800 mm disk as standard and that the disk bolts spaces are 4 by 100.
a bit of a stupid question as im sure you have researched this
The calipers have the same bolt spacing as a N15. The FTO runs these calipers with a 280mm disc but they have a different PCD, but clio 280mm discs have a 4x100PCD.
mmm let us all know how these brakes perform as id like some good brakes lol
are you upgrading the rears aswell?
looking good then, i suppose this is going to be the next brake upgrade for people with bigger alloys, or will these fit under standard 15"?
