Yeah you should be able to. I take it you got the GReddy with it too?
Cheers buddy. Will have to do management research. Do you mean this is where i will get it mapped? I can run it on the de ecu can't I?
http://www.nistune.com/
You can run it in with the DE map using VE injectors, but why risk it. Sort the ECU out before you fire the engine up...have a good base map already in it and then there is no worries.
sorta gutted that I wont be fitting this, but needs must.
Hope you make it into a beast Girth.
It's Hally's :detective:
I didn't even know you had one.. how long you had this under wraps.. knew Sam had one a while ago so im guessing you bought it off him.
Just wondering Girv did you weigh all the scrap you removed from the bonnet... as its something I want to do when I get some aero catch's![]()
AOC (not so) secrets y0
Well I only found out because those photos of the engine are loaded from Hally's photobucket account :lol:
Eww a DE bottom end. That's like shagging a disabled Pixie Lott.
