thought I'd post up a quick vid of it showing how it revs etc...does it smooth enough...
might have to install a shift light as have hit the limiter again quite easily today, though not shown in vid..
  • Like
Reactions: pel
Replaced clutch today...was sure when I got the car it was mentioned it had a nismo clutch...wasn't 100% sure..but when removing old one today..it was confirmed to be nismo.
Assume this wasn't s factory fit?
Sent from my HTC Desire HD A9191 using Tapatalk 2
Was a bit of a let down sticking an LUK clutch in after a nismo one lol..but nismo one was shagged...not sure how long its been in there..cars done 280k + mms..:eek:
^^^ at least ya got part number ready for the next change G?
lol didn't need the above pic from Sam for that, one that came of my car had a part no on it as well, if you look carefully...
car has done 280k kms, god knows when it was last changed, doubt if I will have the car long enough for the next change...
Friday night was not a good night!!! coming back home from the other side of London, thought we'd come back through the city, where you go through some tunnels etc, to have a more fun drive back home, instead of a quiet one via the m25..
Car seemed to be driving great, until the last tunnel we hit, came out of that, and started hearing an odd, noise from front of the car.
stopped over straight away, and engine stopped itself as I came to a stop..
didn't even look to restart it without checking stuff..first was the obvious look around the engine bay for anything obvious, and nothing seen, which has to be a good sign...
checked oil level, and not a drop in there!!! no sign of any milkyness or anything, just plain lack of oil..
now last oil change was done first week in December, and since then I'd be luck if I've driven more then 60-70 miles, until Friday night. so can't see how oil would burn off in such a short space of time..
called Breakdown guys as was no way gonna even drive this home...and as usual they don't listen, even though told em it ain't going anywhere, still send down roadside assistance, who get there over an hour later, guy takes one look at oil level and comes to same conclusion as me...say sorry recovery only...muppets!!! then 3 hours later recovery turns up, (5.26am to be exact) fortunately came in a full demountable so getting the car on and off was not much hassle, without wrecking front bumper.
anyway couldn't check anything yesterday was too knackered, and got up at 2pm after going to bed at 7 am...lol
so plan of attack was :
check what error message was up due to check engine light...
check under car for any sign of oil leaks
remove plugs and check for any oil in there
remove valve cover for any thing there
manually turn engine
if above was good, then remove plug leads and fuel pump fuse and crank
if that good then try proper start...
as expected check engine light error was waste of time, just the usual Knock sensor error which I got on this anyway
no signs of oil leaks under the car
no signs of oil after removing plugs
chain good, no sign of any damage to cams etc.
and then we hit a problem, cannot manually turn the engine, stuck solid...
so what's thoughts guys, put another N1 to rest, break it etc, rebuild it? as it looks like the bottom end gone
get another N1 engine? if anyone has one?
or what's the option with having to rebuild with SR20 bottom end?
any thoughts ideas would be cool, and if anyone knows anyone selling bits that could help with this..
Bad news G. It would be interesting dismantling the engine to see what's happened. The head should be ok. Just put a fresh block on.
aye with the car having done just under 180K miles, some oil burning isn't odd, but for it to all go like that totally mad..
what's best options with blocks then, stick with SR16 or make it SR20? what would people do? if had the choice, I don't want to go crazy..lol
