I'm at a pretty low point of the build right now,
Came home from work and tore into it again with it in my head that it was coming out and that was that. for the record the engine just doesn't lift straight out the top it came out that way in the end but I would never do it again nothing short of pure butchery doing it that way even tho I was assured it would if you insist on doing it that way I would ssay you should remove both upper and lower parts of the sump and the air con and crank pulley as an absolute minimum.
kinda got disheartened then to see a huge hole there after all that work my back is fecking killing me working on a lowered car when your 6ft 4in with no lift is just an out an out no no.
The rear mount and the short drive shaft decided to fight me but lost in the end lol. I got a nice suprise when I opened the bearing caps they were still the genuine N1's due to the part number and the crank hasn't so much as a mark on it neither did the shells the bores except the cylinder one were perfect.
there was however a problem in there that would have led to this anyway when I took out the pistons the other 2 were spotless clean on top but the third one was full of crap on top, I tapped it out and to my amazement the top two piston rings were seized. Explains a little misfire it had from time to time but can't really see why they were seized it had great oil servicing.
Anyway hopefully I'll have the block done and together next week and then I have to find someone to fit oversize valves any one know an engineering shop that would do it I rang a few and they **** the bed at the thought of it.
I was thinking to myself it was hard enough remove it at home with the head off i'm going to go through hell putting it back together with the head on!
Here are some prep and removal pictures. sorry for some there to jog my memory going back together.
Ya can see where some jap idiot put the sump back with too much sealer and it got stuck in the pick up pipe could have ended the engine a lot quicker.
And new and old pollen filter
