Right may as well continue with the engine specs here...
I already have:
Crankshaft 2 litre,
Rods 2 litre,
Another set of sr16ve N1 pistons,
Another SR16VE block.
I had ordered valves and springs but cancelled them POC assures me he has a cheaper place to get them...
I complied a list there friday and placed an order for them off G-Spec in America,
Which Consisted of
1 GSP VVL ALUM UNDERDRIVE CR PLY 135.00 135.00T
1 GSP Aluminum oversized water pump pulley, 2.0 FWD 53.00 53.00T
1 JDM VVL ENGINE GASKET SET 160.00 160.00T
1 JDM SR20 VVL RING SET HI-COMP 90.00 90.00T
1 TIMING CHAIN, SR20 89.56 89.56T
1 CRANK GEAR, SR20 12.15 12.15T
1 CAM GEARS SR20(+/-8*) 125.00 125.00T
1 JDM FRONT COVER/OIL PUMP VVL 240.00 240.00T
1 JDM GUIDE, TIMING CHAIN, CURED (SLACK SIDE) 66.78 66.78T
1 JDM GUIDE, TIMING CHAIN, STRAIGHT (TENSION SIDE) 16.56 16.56T
1 JDM TIMING CHAIN TENSIONER N1 (SR MOTORS) 100.00 100.00T
1 JDM SR16VE VVL WATER PUMP 75.00 75.00T
10 HEAD BOLTS, SR20 3.38 33.80T
1 ESTIMATED EXPRESS SHIPPING 85.00 85.00
The bank account took a firece hammering.
I'm hoping the customs dont get too much of a look in TBH I asked him to put a small value on the package only thing is i'll be screwed if it gets lost in the post!
After that what I should be ordering through POC's source is...
Supertech valves +1mm intake +2 mm exhaust,
Manganese bronze valve guides,
Brian Crower 130lb dual titanium springs and retainers,
ACL Race big and small end bearings,
and an sr20ve 20v headgasket.
I put a brand new clutch into it about 3 months ago and old drove out to the show on that so that will be mint, I'm looking into a flywheel but can't decide?
