MY P11 PROJECTO !!!
Because its leaning into the wind, as such. It should be tilting toward the back of the car!
Well yeah that makes sense i guess,but still from what i have seen it still is correct,there is loads of pics of people installing these the same way i have !
If you like it then leave it as it is it just looks a little strange as the fin usually sweeps backwards, bit more aerodynamic"ish" if you get what i mean.
Lets see the pics you've seen? You sure it's not when it's been fitted to forward area of the roof neat the windscreen and you've mistaken the windscreen for the rear screen like it is in your car?
As said, have it how you like, just odd that you thought that was 'correct'.
So i decided to paint some brackets and bits from the engine,i only got these removed today as it started to rain,
Brackets back to bare metal,
Primer stage,
This is the red fusebox cover i got when i needed one.
Before,
Primer stage,
Both brackets and cover getting final coat now.Got a lot more planned also to do.
  • Like
Reactions: edk
