I had to nip out to shop,so i did as you say David, revved it out of gear to redline,no problem smooth as you like,first time i have done that believe it or not since installing the pullies and flywheel,god it revs quick !
So i gave it some wellie ,seem near perfect only played up this time under full throttle in second gear,going from standstill to redline in first is fine under full throttle,probably just down to needing a tune.As the hesitation is around where it started to show lean on the dyno sheet also,i don't think that's just coincidence thinking about it now.
