My Rides :)
With all the new changes... regarding the MOT rules and regs...
Unfortunately no... which is a shame as it is a relatively clean shell...
Unless I can find a nice local MOTer
It's clean now... easily lady another 3-5 years without any major work...
It's only had 3 patches...2 bottom sills and one rear drivers side top arch...
I've seen allot worse... and so have you...
It will be a shame to get rid of it... but its on to bigger and better things...
But only time can tell... there is a lot which can and will be done...
Welcome to 2012
If a car was fitted with airbags as standard.. they must still be in fully functional order airbags light and all...
And
If the car was fitted with pre loaded retractable seat belts they must be still be fully functional...
And there is a couple more as well...
It takes all of 5 minutes to change a steering wheel, whats the big fuss?
And re: the seatbelts, if they arent there (along with no rear seats) then it's irrelevant.
I don't have any seat belts at all ... just harnesses... I was referring to the front seat belts...
And if the car was built with ABS and airbags as standard they all need to be fully functional...
It's all being done to stop people modifying cars
MOT test for cars
New mandatory test items from 2012
If you've been happily ignoring a warning light because it's not checked in the MOT you could be facing an MOT failure and an expensive repair bill in 2012 because of changes to the test.
The Department for Transport is adding a number of new mandatory test items to the annual MOT from 1 January 2012 to comply with a revised European testing directive.
The aim of the revised directive (2009/40/EC) is to harmonise minimum test requirements across Europe and make sure the test reflects the electrical/electronic complexity of modern car safety features.
The new testable components* are subject to a 'bedding in' period during which any defects found in these components will be advisory only.
The main changes from 2012
Electronic parking brake
Electronic parking brake controls are now included and must be present and not inappropriately repaired or modified - repair obviously likely to adversely affect the roadworthiness of the vehicle or modification that has seriously weakened the component.
(The 'inappropriately repaired or modified' check is to be applied to a wide range of systems and components throughout the vehicle.)
The car will fail if an Electronic Parking Brake warning lamp is illuminated to indicate a malfunction.
Electronic Stability Control
Checks of antilock brakes will be extended to include Electronic Stability Control if fitted. The tester will check for the presence and correct operation of the ESC malfunction warning light together with looking for obviously missing, excessively damaged or inappropriately repaired or modified components and electrical wiring, as well as an ESC switch missing, insecure or faulty.
Warning lights
As well as electronic parking brake and electronic stability control warning lights (where fitted) the MOT test will also include checks for the correct function of the following, where fitted;
Headlight main beam warning light
Electronic power steering warning light
Brake fluid level warning light
Tyre pressure monitoring system warning light
Air bag warning light
Seat belt pre-tensioner warning light
Steering & suspension
The new test includes a check on the presence and correct function of the steering lock where fitted as standard.
Missing, or split/damaged dust covers on steering and suspension ball-joints will result in failure if they will allow dirt to enter the joint.
Power steering fluid level must be above the minimum level indicated on the reservoir.
Lighting
Products on the lens or light source that obviously reduce the light's intensity or change its colour will become a reason for failure – applies to front/rear position lamps, registration plate lamps, stop lamps, rear fog and direction indicators,
Headlight requirements are updated to take account of the particular characteristics of High Intensity Discharge (HID) lamps.
HID headlights can cause dazzle if they are dirty or aimed too high so car manufacturers must fit headlamp cleaning and levelling systems. Where HID or LED dipped beam headlamps are fitted the tester will switch on the headlamps and check the operation of any headlamp levelling and cleaning devices fitted.
The car will fail if a headlamp levelling or cleaning device is inoperative or otherwise obviously defective.
If a headlamp bulb is not seated correctly the resulting beam pattern will be indistinct and this will result in a test fail.
Electrical wiring and battery
An insecure battery will be a reason for failure as will a battery that is leaking electrolyte.
Visible wiring that is insecure, inadequately supported or likely to cause a short will also result in a failure as will wires bared by damaged insulation.
Trailer/caravan electrical socket
There will be a basic security/damage check of 7-pin sockets,
13-pin sockets will be subject to a full electrical connectivity check and incorrectly connected or inoperative circuits will result in failure.
Tyres
Tyre pressure monitoring systems fitted to vehicles first registered after 1 January 2012 must be working correctly and not indicating a malfunction.
Supplementary restraints
The vehicle will fail the test if any airbag fitted as original equipment is obviously missing or defective.
A seatbelt pre-tensioner fitted as original equipment but missing or that has obviously deployed will be a reason for failure.
Seatbelt load limiters that are missing where fitted as standard or folding webbing type limiters that have obviously deployed are also reasons for failure.
The vehicle will also fail if an SRS malfunction light is missing, not working or indicating a fault.
Speedometer
The car will fail if a speedometer is not fitted, is incomplete, inoperative, has a dial glass broken/missing or cannot be illuminated.
Seats
It must be possible to secure the driver's seat fore and aft adjustment mechanism in two or three different positions. On electric seats the motors must move the seat fore and aft.
Doors
A rear door that cannot be opened from the outside using the relevant control is a new reason for failure.
Doors must be easy to open and close – hinges, catches and pillars will be inspected.
Towbars
Inappropriate repair or modification to the towbar assembly will be a reason for failure if judged likely to affect the roadworthiness of the vehicle/trailer.
Exhaust
A catalytic convertor fitted as original equipment but missing will be a reason for failure.
Fuel system
Damaged or chafed fuel pipes will result in failure.
(updated 26 March 2012)
* The new testable components subject to the 'bedding in' period are:
headlamp levelling and cleaning devices when fitted for HID or LED headlamps
main beam 'tell-tale'
battery - including batteries for electric or hybrid vehicles
electrical wiring connectors
trailer electrical socket security and damage
operation of 13-pin trailer electrical sockets
operation of the steering lock (where fitted)
electronic power steering malfunction warning indicating a fault
electronic parking brake control and malfunction indicator lamp
electronic stability control components including switch and malfunction warning
brake fluid warning lamp illuminated or inoperative
tyre pressure monitoring systems
secondary restraint system component including airbags, seat belt pre-tensioners, seat belt load limiters, and SRS malfunction warning lamp
engine mountings
speedometer
indirect vision devices - where they replace obligatory mirrors
From Vosa:
I know you will probably take the "such as rally cars" at face value, but I wouldnt worry too much.
nah, some guy just posted that up after he went to a VOSA conference.
The wording they have used is just to apply to mr average with an airbag missing on his otherwise standard mondeo, if your car is obviously a "track" car or whatever, you should be fine.
Good. I would like to think common sense still prevails. So if harnesses are fitted then it's obviously safe still, for example.
Well I do have other alternatives if found to not pass the new MOT regulations...
Just prepareing my self for the worst situation...
It's just when I did the last MOT last week I was told by him that it would not pass with the new regulations in place...
Tell him to get bent. Just wire in the airbag and ABS light to the MIL. Comes on and goes off like normal then.
Where theres a will theres a way. Stop pussy footing bitch :p
