well more goodies arrived today, just need to spend some time to find somewhere to do the work, instead of spending the an hour in the gym, then spending about 2 hours after alternating between the sauna the plunge pool and the steam room :sweatdrop:
Yes the GTS (non-Turbo) just came with twin pots or single pots. My twin pots are the same. It's the GTS-T (turbo, obviously :lolthat had 4 pots but I always thought it was the ones in the picture I posted which use larger 310mm discs (iirc), but the ones you have will use 280mm discs and I thought they were only on the Z32 (with cast iron versions on the S14). But obviously this isnt the case and Nissan fitted them to the R33 at some point.
Oh the joys of unemployment...![]()
The title is probably like that Phil just so they get the catchment of searches because those calipers do fit all those cars.
I've got to admit that even with the FAST evidence I'm still sceptical. It's because the calipers of that design DO use 280mm discs normally, and the 296mm (sorry I got the 310mm wrong early) is normally the calipers I pictured. So to see the 280mm design (looking) ones claiming to be 296mm versions throws up alarm bells.
I personally think it will be ok using 280mm discs. I found out that the hub I was using had a crap wheel bearing so that made a bit of difference but to be honest 282 or 284mm disc would be better I guess.
I've re-titled and stickied the thread that relates to as I can see the question of brake upgrades on the N16 being asked more and more in future as more people mod the N16 - http://www.almeraownersclub.com/threads/28971-Nissan-4-POT-Calipers-on-an-N16-Brake-Upgrades
