well updates have been kinda slow here so i'll let you know where i'm at, after demolishing and tracing back the wiring loom on the N16 (on bbq day too
![Frown :( :(](data:image/gif;base64,R0lGODlhAQABAIAAAAAAAP///yH5BAEAAAAALAAAAAABAAEAAAIBRAA7)
i'd had enough of wiring for a while so i'd been avoiding starting the wiring on the VE loom and as well as working on some of nistros stuff i done some other things on the N16, like instead of using the N16 throttle cable which 'just' worked, i made up a hybrid of an N15 and N16 throttle cable that works perfectly and has the pedal stay in the right spot
n16 cable on the bottom with n16 bracket on the left, and the n15 cable with the n16 bracket plate
close up of bracket plate of the hybrid cable using the cable from n15 and bracket from n16
nistro also made up some radiator top brackets from some n15 ones which were modified to work with the n16, and i chucked on my only bit of pointless bling (well it's not fully pointless but you know what i mean :lol: )
i also filled the gearbox and engine up with some oil, the engine oil will be changed after a few hundred miles to something better, i just want to run it on some semi synth 10w40 to see how healthy it is
i also shortened the powersteering pipe and re did my coolant pipes that connect to the heater matrix by sleeving to the smaller n16 pipes about 4 inches before the matrix connections using some alu pipe as a sleeve, this is done by fitting the larger ve pipe over the n16 pipe with the 16mm alu pipe inside the n16 pipe (n16 heater pipes are 16mm inner diameter) and then clamping them all together with a jubily clip, i also used some 20mm alu pipe to and a couple of jubilee clips to split and join the powersteering pipes as they are 20mm inner diameter.
so today after all my dodging and procrastinating i started on the wiring
the connectors that interface the engine loom to the main car looms, these are what i need to mostly splice the ve loom into and it took a while to trace and label them all lol
due to only having a few hours to work on it today as i was doing other stuff for friends and family all i got done was the alternator, the pnp switch and the reverse switch, but tomorrow should go much better and i'm hoping to have it running by thursday night!
so wish me luck guys :lol:
