(reverse switch, load adjust, speed sensor, water temp, oil pressure, start signal, charge warning light, powersteering pressure switch, lambda, fuel pump etc etc etc) says something completely different, and while i don't mind risking blowing N16 parts i cant risk the VE ecu :/
all im saying is use another SR ecu to get the wiring done. if you connect the consult plug into the ECU you can test virtually everything before you start the engine. he does not want to blow the VE ecu.What?? ^
Good news then
Don't suppose you want to bring back a used B15 SpecV transmission? :lol: ah but seriously can I get a nismo oil cap sent to you to bring back please?
-mobile phone post-
