Nah, I dont mind you sharing the dyno chart at all..
Its not a very accurate header test as the setup changed a lot in between testing, but its something i suppose. Its not the all singing and dancing gains everywhere graph we'd all like to see. But it was promising at least to see gains somewhere considering it wasnt tuned.
Phils particular header is better than mine that was tested, as mine has a lot of unecessary cuts/welds, and a below par transition from the first collectors to the secondaries. After learning from my mistakes in the first one Phils header is improved and will flow a bit better, and has slightly improved ground clearance.
