shaggy_master
brapp brapp!
Hope it works out like we discussed
not to self: appreciate french cars as well as jap sometimes
get in. now comes the hard work
Yum yum...
Good luck with it mush.
It's because it didnt have VE in the thread title before, only N16, so you obviously didnt care to look :hammer:
:whistling: i wish i could say you don't have a point
i only tend to click the special n16 threads, how bads that.
Hope it works out like we discussed![]()
good luck. My SR20DE is going in next week end
also have a look for a Primera P11 Gearbox mount
The almera gearbox mount was on front face where as the Primera's were mounted on the top
also I think the QG15DE gearselector rods might work as I posted in my QG15DE to QG18DE gearbox swap thread.
oh and it might not have NATS on the ECU but it might have NATS separate to the ECU like I had on the P10 ECU
lol he's only trying to wind us up Phil![]()
if its NATS V1 its fairly easy to bypass as its only a few wires and relays. I took loads of pics of when I got my SR20DE started on the bench. wiring is the head ache as if 1 wire is not connected the engine won't start thats why I started the engine on the bench first. you will need to bypass the original immobilisers on the N16 as once you disconnect the original ECU the NATS won't work.yeah if the n15 and p11 mounts give me what i need i'll be well happy mate, thanks again for sorting them for me :shades:
good luck with it mate, i'll be looking to your install to see what mounting problems i'll face. i was thinking i'd need the qg18 selectors as they are working on your box, but iirc the gti box is the rs5f32a not the 70a so you may be right that the qg15 selectors will work as the gearbox is an rs5f30a so may be round the right way. i'll know more when i get to ripping out the qg. afaik mate the jdm never recieved any of the nats stuff at all, but i'm open to be corrected on this? anyone?
im just posting for refference
N15 GTi mount layout
I just noticed that the shifter rod stabiliser mounts on the bracket (right hand side of the shifter). on the N16 QG18DE and the P11-144 gearbox the shifter rod stabiliser mounts onto the gearbox (left hand side of the shifter). On the N16 QG15DE the stabiliser rod is mounted on the bracket very similar to the N15 (right hand side of the shifter). Maybe if you was swapping using a QG15DE I would use a N15 GTi box
edit (some more info)
The mounting points
RS5F30A is the N16 QG15DE Gearbox and the RS5F70A is the N16+P11-144 QG18DE gearbox and SR20DE gearbox
P11-144 SR20DE
I Personally think it really depends on the car. with the phase 1's you got manual heaters and loads of other things that are manual. with the phase 2 N16 SE (my one) I got climate control, on board computer (MPG etc etc) I don't have a speed sensor to detect the speed I don't have a throttle cable etc etc.YES YES YES YES!!!! :taz:
Bout bloody time![]()
If i were to do an N16 SR coversion again :whistling:, id be inclined to use a full N15 GTi wiring loom, engine bay, interior, lights ect ect
i wont even have vz-r like drag strip performance
but as i've said from the begining 'torque is cheap' in the sr16so this year is just for the swap and fixing all of the eventual niggles that always arise in swaps of this type, and next winter is when she'll get craked open and stroked, and if money is tight possibly a slight hone/overbore to 86.5 or 87mm as i should get away with just using oversize rings for that, or if money is ok i'll go for an 88mm overbore to 2.1L along with a full strip and rebuild. but i'm getting way ahead of myself here, as i need to find a bloody barn/garage/unit to do the swap in first lol
