well had to take the passenger side drivehaft out this morning as my bro didnt put the circlip on the shaft.. so did that topped up the gearbox.. tightned everything up and iv managed to put 70miles on her today driving up and down the local bypass..
3 problems so far..
first The VVL isnt engaging.. but the soleniods work so duno if iv blown the switch in the ECU or the ECU is in limp mode as its overfueling its tits off! but if the soleniods are working i can get the dastec to do the switching..
second problem the exhaust is now catching as either the de-cat or the manifold downpipe is a tad bit to long about 1cm.. but thats not a big problem
3rd once its warm its like trying to push a brick through a leterbox to get it in gear because of the clutch iv adjusted it as much as i can but its still on the floor its drivable but annoying as fuck lol
the car sounds well but its very blunted.. due to the fuel and lack of ign.. plus iv only reved her to 5.5K a couple of times.. fingers crossed once its mapped it will come alive..
15w50 mineral oil.. my run in procedure is driving it about if its gona break it wil break.. most of that 70 miles was sat in 5th at 40.. with some runs to 60.. i did a few full throttle bits in second to 5.5k the backed off checking for smoke..
its been varied iv been driving all over went for petrol at two different garages for somthing to do.. its had full throttle in all gear plus full throttle in 5th up a hill for some propper load..
