so it is fuelling but not sparking at all?
It's fueling and sparking, tested all that in the freezing cold last night.
oh yeh sorry misread, in that case i'm fully with corbs on timing. can't see any other reason and i've had similar weird issues before
what i dont understand is why it was running before, no changes made to the car and it doesnt run now...
It is strange I agree.
Unless you've blown a fuse or disturbed something under the Inlet while swapping the Starter Motor? (IACV, TPS, MAF, Vac lines?)
Joe
Fiddle with the timing. Mine did that before I fettled the dizzy.
try changing the fuel filter. if you've run it low/out of fuel, could have shucked all the shit out of the bottom of the tank, partly blocking the fuel filter and cause low fuel pressure in the rail.
Why? Doing that is how you end up making the situation even worse and masking the original problem.
I can understand eddies comment to be honest. As it gives downforce it must be in the air flow, therefore if the mounts are loose, there is a lot of air pressure acting against it.
Well fortunately it's very simple in the realms of understanding why a spoiler which is designed for downforce will fly off if the mountings let loose, you don't need a degree a child could understand the principle
