TBH I didn't get an explanation to why the engine cuts out while driving. They had suspected something loose in the wiring but wouldn't know where to start looking. Typically it never cut out when they had it, in fact, when they came to trailer it, it started first time?! Probably by then the spark plugs were dry enough to spark as they could have got wet from constant starting attempts?
The map settings loss were probably due to low battery period long enough for the settings to be erased. This was sorted. TJ were pushed for time last week - they had an engine build that had to be ready for the Easter weekend so when I got there they didn't have time to have a handover - they just gave me the keys.
Hopefully, it won't be so manic this week and I can get 5 minutes of their time to go through it. In terms of the MAF, I had no idea it wasn't plugged in; originally when this project began I had intended to change the MAF to the Z32 but was told that the ECU didn't need it?! You guys probably understand this better than I do as to how it works without one, if this is the case.
I assume the MAF still being there and not being used is only a little weight disadvantage? I'll probably check with TJ before removing it.
So I'm non-the wiser. She works for the moment - probably give her a nice run when I see Stu on Monday.
