Little update, been working on the car these past few days.
First up its the front crossmember, it was rather rusty and I know they are a weak point on micras, so I decided to spruce mine up a bit.
Attacked with a wire brush, this shows the extent of the rust.
A couple of coast of kurust rust eater gel, left that on about 2 and a half hours.
Wiped it down, then a nice coat of red oxide anti-rust paint.
And the first of two coats of hammerite black, really thick stuff!
I made sure that any bolt holes I was reusing had the bolts in them so as not to block them up. It now has the final coat on and I should be waxoyling it after reassembly.
The gearbox and head were rather tatty compared to the nice shiny block so some sanding and painting was in order to spruce them up a bit and prevent oxidation.
Gearbox after wire brush attack.
After Painting.
A few of the engine and box.
The engine bay was filthy so I bought a big can of 'gunk' to clean it up, worked a treat!
Then I decided it needed some protection so the entire bay now has about 3 coats of lacquer on it.
The SSAC exhaust manifold with new copper gasket is now fitted, all the studs were treated to some copper grease to prevent them seizing. Tomorrow I'm planning to crack on with fitting the inlet manifold and water pipework.
We had a few issues with a seized timing chain tensioner but some 'persuasion' with a hammer seems to have sorted it out.
More to come later in the week!
