was that bushing causing problems.... should be easy done with a piece the exact side of the bushing on one side and a piece that the bushing can fit into then on the other side, a threaded bar though the middle and a couple of nuts.
True enough, and they stitch/seam weld shells because they do twist, as the length of the car is much longer so leverage has a much greater effect. if you want to weld something on the chassis to improve handling plate over the bottom of the rear axle, as boxing it it will make it much harder for it to twist
also n15... you can buy a toolset for doing exactly that, but if you have a press and a lathe at your disposal why waste money on a tool you'll rarely use?
yeah them bushes are tight as fook in the arms for sure; even in my brand new arms, they were hard to remove to put in the polys. looks like good work, looking forward to the updates
