Sams VZ-R N1
They are perfect for what I want.
15s
Good tyres
Light
Clear the Wilwoods
They are only 6 months old bolted to a car twice for 2 airfield track days :)
-Phone-
Sam your willwoods.. same as mine aren't they? are you sure they are 285mm disc? Mine are 280 and I only see 280mm GTiR setups listed
What pads are you planning to use.. using Greenstuff atm an no likey
Im honestly over the moon Ive found these wheels in Silver, not interested in changing the colour they are practically brand new not a mark on them.
The Tomei's were only 15x6.5 and Ive wanted 15x7's for quite a while now, give me the extra width for the tyres which are wide enough as it is :)
Ive the updated version of the Wilwood calipers, Ive a preference of pads I want but cant track them down yet, few other options Im considering aswell.
Coloured wheels are so played out now days everyone seems to over look how good silver can actually look.
  • Like
Reactions: edk
Was about to say that earlier. Cos silver wheels come standard on everything, everyone wants to change colours to be different/modded. Silver's gonna be the new coloured soon.
I really like em in silver tbh, will look good and clean and fresh against the black.
It's a hyper silver or highly metallic anyway on those wheels so stands out a bit better than OEM silver :)
Last night with the break in the weather I started on the front end of the car.
Removed;
Suspension
Wishbones
Driveshafts
Track Rod Ends
Hubs
Brakes
Now I can set about stripping/cleaning/painting and rebuilding everything.
I still need to strip out the gear linkages and trial fit the new shifter.
-Phone-
Thatl do
Freshly Painted Wishbones
Stripped, Cleaned, Greased, Painted Coilovers (Raised 5mm from previous height and a slight bit more preload)
Freshly rebuilt shafts
Trial fitted some of the subframe collars but they need a bit of tweeking, should have them by next weekend.
